Forums >> Revit Systems >> Technical Support >> Uninstalling RAC 2012 problems..
Mon, Jul 4, 2011 at 11:34:40 AM | Uninstalling RAC 2012 problems..
ramus2
Yes I know, there is guides online how to do it but before you go on you should know that I have already tried them all. I did everything as it was listed here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16828836&linkID=9243099
But still RAC 2012 just wouldn't want to be removed or somehow corrupts the re-installation so it show's that RAC is "already" installed and wouldn't install it anew. I have literally tried everything and still my machine think's that RAC 2012 is already installed.
If anyone have any fresh idea's please I'm open for all of them!
Thanks in advance,
Ram
Tue, Jul 5, 2011 at 9:14:15 AM | Uninstalling RAC 2012 problems..
Yes. The clean uninstall instructions not only do not fully clean up after the install, they also don’t help much after a failed install. We were not able to build a deployment of Revit 2012 on the PC and it would not install Revit after the failed attempt. It takes a system restore to get back to where it doesn’t have some hidden junk that prevents things from working right.
Fri, Sep 23, 2011 at 4:26:44 PM | Uninstalling RAC 2012 problems..
stamenvalchev
Same problem, no solution! Sad Just backing up and about to reinstall Windows ... I am totally sure that it's a problem with Windows and not with Autodesk's products.
RAC 2012 Highlight / Select issues
Wed, Jul 27, 2011 at 5:47:35 PM
Revit 2012 crashes at splash screen HELP!!!
Fri, May 17, 2013 at 1:13:24 PM
Setting a Default Family Type - RAC 2012
Wed, Jan 23, 2013 at 10:09:23 AM
RAC 2012 hangs on splash screen
Mon, Jul 25, 2011 at 7:22:10 PM
RAC 2012 crashing when exporting image [shadows on]
Sun, Jun 19, 2011 at 8:50:21 AM
Page generation time: 0.2867
