Forums >> Revit Building >> Technical Support >> STL or VRML formats
Tue, Nov 22, 2005 at 7:17:41 AM | STL or VRML formats
Cancaq
Is it possible to save or export revit project STL or VRMLformats? If your answer is yes, explain the way of it please.
Tue, Nov 22, 2005 at 5:05:32 PM | RE: STL or VRML formats
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You would need to export to DWG first then in another program export to these formats...
Tue, Nov 22, 2005 at 5:44:22 PM | RE: STL or VRML formats
eldados
eldados Avatar
4.5 Stars: 8 Votes
Like spoty says you will need another program to converte to vrml, check this: http://vrmlworks.crispen.org/convert.html
Integrator
KarelCAD
Tue, Apr 25, 2006 at 5:31:56 PM | RE: STL or VRML formats
cwentworth
Sure thing. Just save your revit file as a dwg polymesh. Then bring it into Autocad and save it as a vrml. To do this you need to get the vrml plugin for autocad from www.xanadu.cz. I make solid models using 3d printers so i am a pro at it. If you need help let me know. Chris www.3drp.com 714-848-4559
.stl file creation?
Thu, May 17, 2007 at 12:50:53 PM
hoe do you export an STL file for 3d printer
Mon, Jan 5, 2009 at 5:10:05 PM
How do you export to STL with materials
Tue, Oct 4, 2011 at 9:54:31 AM
stl files
Fri, Mar 8, 2024 at 10:29:41 AM
Exporting Topo to STL as a solid for 3D Printing
Fri, Feb 9, 2018 at 4:51:21 AM
Page generation time: 1.7104
