Forums >> Community >> Newbies >> using steel bearers and joists ?
Sun, Jul 3, 2011 at 8:31:41 PM | using steel bearers and joists ?
skware
Hi I am new to Revit and I am trying to design the base for some relocatable cabins (site sheds) that are build on a steel base with C-channel skids and SHS joists I am trying to figure out how to build this frame but can't seem to get it to work? I have been trying to build it as a custom component but the steel profiles I want to use don't want to load? is there a good online tute for this?
regards Amos.
attached is a rough sketch of what i want to do in revit.
Mon, Jul 4, 2011 at 6:03:54 AM | using steel bearers and joists ?
4 Stars: 205 Votes
You need to read your help menu and the "TUTORIALS", they are your best help, you can search in "youtube" for free revit videos.
 Maybe this can help you: http://www.revit-waterman.blogspot.com/
Edited on: Mon, Jul 4, 2011 at 7:21:32 AM
Mon, Jul 4, 2011 at 7:12:02 PM | using steel bearers and joists ?
skware
Thanks I ended up figuring it out. but I'm sure there is an easier way I'll check out that blog.
Bearers & Joists
Fri, Jun 24, 2011 at 2:50:39 AM
Steel Joists
Sun, Mar 15, 2009 at 9:22:19 PM
Family Needed - Top Chord Offsed Double Pitched Underslung Steel Joists
Tue, May 18, 2010 at 11:40:49 AM
timber and steel to have different detail levels
Fri, Sep 3, 2010 at 8:29:04 AM
2D Open Web Joists in Section View
Mon, Aug 27, 2012 at 1:07:56 PM
Page generation time: 0.3359
