Forums >> Revit Systems >> Technical Support >> roof tiles in revit 2010
Fri, Jul 1, 2011 at 3:52:14 PM | roof tiles in revit 2010
ARTIZMO
i'd like to put roof tiles on my roof so it looks nice when rendered but not sure how to do so. any ideas?
Fri, Jul 1, 2011 at 4:16:05 PM | roof tiles in revit 2010
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Well, do mean ceilings?  Or applied directly to the underside of your roof? Either is quite possible, but dropping in ceilings is an extra step.
Ceiling tiles, in revit, are just a render material like mahogany or stone.  So If you go into your roof or ceiling properties, you can tell the bottommost material to be "12x12 acoustic ceiling tiles" Or something like that.  It's a default material that comes with revit, it should be set up to render correctly out of the box.
Sat, Jul 2, 2011 at 6:09:10 AM | roof tiles in revit 2010
4 Stars: 205 Votes
Look at the bottom of this page and you will see similar threads about your question.
3D Roof Tiles for temple
Sat, May 15, 2010 at 6:55:41 AM
tiles 3d on the roof
Fri, Feb 23, 2018 at 10:45:21 PM
ROOF TILES
Fri, Feb 23, 2018 at 10:52:53 PM
How do i make roof tiles appear in elevations an sections?
Tue, Sep 27, 2005 at 6:47:20 PM
Parametric Roof Tiles
Tue, Aug 3, 2010 at 3:48:57 AM
Page generation time: 1.8859
