Forums >> Revit Building >> Technical Support >> 2D ceiling light object
Fri, Jul 1, 2011 at 12:49:28 PM | 2D ceiling light object
Warchitect
4 Stars: 5 Votes
I am making a ceiling based object that is just a 2D shape. When I place it on the ceiling it disappears. if I hide the ceiling you can see it, so it seems that the ceiling is obscuring the 2d light symbol. how do I get it to show? do I use "model" lines? or a masked region?.
thanks
warc
Fri, Jul 1, 2011 at 1:54:25 PM | 2D ceiling light object
It should work fine if your light is hosted to the correct side of the ceiling.  If you ceiling has a surface pattern, you would want to use a masking region and no reason to have additional linework.  Just use the right linew for the masking region.
Obviously, this light would never be used in a 3D view.
Tue, Jul 5, 2011 at 1:52:32 PM | 2D ceiling light object
Warchitect
4 Stars: 5 Votes
Cool thanks I got it. now how do I get it to stick to the underside of the floor above. (its a floor, not a ceiling, but it is the ceiling of the floor below.)
the new symbol only wants to hit on ceiling parts. should I just make a generic one with no hosting?for that matter: how would you even get a 3D light in the floor underside? wont leet you place it..
Tue, Jul 5, 2011 at 2:53:16 PM | 2D ceiling light object
There is a default ceiling in Revit (generic) that has no thickness and will host ceiling objects.  That is what we use on the bottom of exposed structures.
Light Fixture on Sloped Ceiling Displays incorrectly in section
Wed, Jun 1, 2016 at 6:43:11 PM
Recessed cans = no light
Fri, Mar 6, 2009 at 7:41:57 AM
Light Fixtures Not Placing/Cutting Custom Ceiling Family
Tue, Apr 14, 2015 at 7:06:55 AM
Ceiling objects cut by walls
Fri, Nov 20, 2009 at 12:58:09 AM
FLOOR / CEILING PROB WITH HOSTING LIGHT FITTINGS
Thu, Dec 15, 2005 at 10:30:38 PM
Page generation time: 2.9639
