Forums >> General Discussion >> Revit Project Management >> Brick Piers
Thu, Jun 30, 2011 at 8:58:14 PM | Brick Piers
Oatsey
I'm a noob to Revit Architecture and need help knowing how to create 230x230 Brick Piers with Antcapping on top?
Any guidance would be much appreciated.
Thanks
Fri, Jul 1, 2011 at 11:30:33 AM | Brick Piers
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
not quite sure what antcapping is, but you could extrude a model in place column or create a column as a family, with brick facade texture. Model in place is the pull down under component on the home ribbon.
Wed, Jul 6, 2011 at 5:13:06 PM | Brick Piers
Oatsey
Antcapping is the same as pier capping. Do you have any idea how to place the capping on top of 230x230 brick piers. Thanks
PS. Figured out the brick piers thankyou
Fri, Jul 8, 2011 at 3:14:27 PM | Brick Piers
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
Not sure if I understand you correctly...but in the past I have capped columns by creating a new family using the Generic Model - Face based Template. Just model the cap and load it in, this way you can lock it to always sit ontop of the column.
foundation piers
Mon, Feb 18, 2008 at 5:36:11 PM
How can I show concrete piles/piers beyond in a section view
Tue, Sep 20, 2005 at 6:59:33 PM
concrete piers
Wed, Apr 4, 2007 at 5:12:53 PM
Continuous footings for the Piers
Mon, Sep 30, 2013 at 12:23:16 PM
Incorporating piers into foundation walls
Mon, Feb 18, 2008 at 4:38:44 PM
Page generation time: 0.3386
