15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Degrees symbol
How does one write in the degrees symbol, for example i am trying to rotate something with degrees, minutes and seconds.
----------------------------------- VND |
first, I assume you went to Setting-->Annotation-->Dimensions-->Angular and changed it there to dgrees minutes seconds... if not, do it.
2 ways to rotate:
1. angular dimension to your object or line, click on it and the dimension will highlight, click on the figure and change...
2. click on the object and type RO (for rotate) you can either rotate using your mouse or input the angle you want up top in the box called "angle" just input i.e 20 30 67 with the space.
HTH
Thanks for that eldados... that worked.
Symbol Text |
Thu, Dec 10, 2009 at 5:39:08 PM
Showing doors at 45 degrees |
Thu, Apr 17, 2008 at 8:05:54 PM
Annotation Symbol Text - Keep Vertical? |
Thu, Dec 15, 2011 at 3:23:42 PM
new symbol from 2009 wont load as symbol in 2011 |
Wed, Jul 6, 2011 at 2:09:39 PM
Text editor |
Thu, Jul 22, 2004 at 12:27:22 AM
