Forums >> General Discussion >> Wishlist >> 5 Bricks to 16" Hatch Pattern
Thu, Jun 30, 2011 at 11:08:18 AM | 5 Bricks to 16" Hatch Pattern
dch121
Does anyone know how to create a hatch pattern in Revit that shows 5 brick courses high for 16"? Engineer Brick. I had one in AutoCAD as part of the detail component Manager, but it doesn't seems to appear in Revit.
Thu, Jun 30, 2011 at 11:25:26 AM | 5 Bricks to 16" Hatch Pattern
If you have the hatch in CAD, you can use it in Revit.  You would probably want it as a model hatch and that may require adding a line of text to your pat file.  See if you can find the pat in your CAD files.
Fri, Jul 8, 2011 at 11:22:07 AM | 5 Bricks to 16" Hatch Pattern
Johnzo142
Here's a cool add-in that I found helpful for creating hatch patterns.
http://mertens3d.com/revit-2011-addin-portal/hatch22/hatch22.php
I need a simple hatch pattern for a waffle ceiling
Fri, Jan 18, 2008 at 12:53:44 AM
Vertical Plywood Hatch Pattern [ 1 2 ]
Mon, Aug 27, 2012 at 4:04:30 PM
17
Exporting hatch pattern
Thu, Sep 18, 2014 at 6:27:35 PM
hatch pattern not printing
Mon, May 8, 2017 at 12:56:51 PM
Hatch pattern
Tue, Jan 13, 2009 at 10:23:47 AM
Page generation time: 0.5524
