Forums >> Revit Building >> Technical Support >> Area Plan Lines will NOT join to form a closed loop! (Revit Arch. 2011)
Wed, Jun 29, 2011 at 10:32:59 AM | Area Plan Lines will NOT join to form a closed loop! (Revit Arch. 2011)
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
I'm finally getting around to exploring the area plan calculation tools, and when I allow Revit to automatically trace the border of the building, it creates a bunch of segmented lines, which would be fine if I could just trim them correctly, but that doesn't seem to work.  I can't tag the gross area until the lines are looped (right?) but the lines end up doing things like in the pictures below.  The grips show that the lines are connected, but they are drawn as offset...?
Thanks for the help.
Wed, Jun 29, 2011 at 10:40:06 AM | Area Plan Lines will NOT join to form a closed loop! (Revit Arch. 2011)
If you use the automatic sketch, it will look like what you show but it will work correctly.  You can also sketch it manually if you prefer.
Wed, Jun 29, 2011 at 10:58:15 AM | Area Plan Lines will NOT join to form a closed loop! (Revit Arch. 2011)
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
Maybe I'm doing something wrong, then, because I tell it to automatically generate the sketch, but then it doesn't consider it a closed area.  CryingSee attached image, taken right after it generates the sketch, before I alter anything).  And I can't get the area to close by trimming...the lines are just behaving strangely.
Wed, Jun 29, 2011 at 11:27:45 AM | Area Plan Lines will NOT join to form a closed loop! (Revit Arch. 2011)
Your curtain wall is not room bounding so no area boundry.
Wed, Jun 29, 2011 at 11:33:58 AM | Area Plan Lines will NOT join to form a closed loop! (Revit Arch. 2011)
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
I thought for sure that would have solved it, but when I checked that curtain wall is already room bounding...
Wed, Jun 29, 2011 at 11:50:12 AM | Area Plan Lines will NOT join to form a closed loop! (Revit Arch. 2011)
Then something is wrong with the CW. Is it hosted on the floor?  Does it go wall to wall?  Is their a little wall under it that is not room bounding?  Your problems are there.... look some more.
Parapet Profile Closed Loop Error
Fri, Mar 8, 2013 at 12:12:04 PM
CLOSED LOOP?
Mon, Dec 30, 2019 at 2:55:23 PM
Creating and Loading Profiles
Tue, Apr 8, 2008 at 12:19:55 PM
Parking on Grass
Fri, May 8, 2009 at 3:20:20 PM
Roof join (s)
Tue, Feb 14, 2012 at 8:11:44 PM
Page generation time: 2.1285
