Forums >> Revit Building >> Technical Support >> Door Tag driven by door parameter.
Tue, Jun 28, 2011 at 10:56:36 AM | Door Tag driven by door parameter.
PattheMull
Hi
Any help greatfully received.
I have added a Shared Parameter to a door type, specifing that it has a Vison Panel, an alternative type does not have the parameter added. I am now trying to get a Door tag to display the characters 'VP' in those door types that have the parameter included and have a 'blank' space ( i.e. nothing) in the tag of those doors that do not. I have tried  adding an on/off visibility parameter which  works to a point, the doors with VP value added show the 'VP' characters correctly but the type without the value show a '?' symbol. not the 'blank' .
Anyone have an idea to achieve this or an alternative (better) solution.?
Tue, Jun 28, 2011 at 12:01:00 PM | Door Tag driven by door parameter.
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
Sound like you need to load the shared parameter into the project
Manage Tab -> Project Parameters -> Add -> Shared Parameter -> Select
Why not just add the missing paramter to the other door type vs using shared parameters?
Edited on: Tue, Jun 28, 2011 at 12:04:31 PM
Edited on: Tue, Jun 28, 2011 at 12:04:59 PM
Edited on: Tue, Jun 28, 2011 at 12:22:12 PM
Edited on: Tue, Jun 28, 2011 at 12:27:47 PM
  • Ability is what you're capable of doing.
  • Motivation determines what you do.
  • Attitude determines how well you do it.
Quote by:  Holtz, Lou
  • Life is all about the attitude
door tag exposing the door-width
Wed, Sep 16, 2009 at 4:52:04 PM
Door Tag Parameter-Need it to be the door opening number, not the door type.....
Thu, May 7, 2009 at 4:09:39 PM
Door tags and Door Type ID
Wed, Jul 10, 2013 at 1:40:25 PM
Door Tag Locations.
Wed, Aug 24, 2011 at 12:48:11 PM
Door tag lables/parameters
Mon, Jul 10, 2006 at 1:39:50 AM
Page generation time: 0.8723
