Forums >> Revit Building >> Technical Support >> How do you chamfer two different wall types?
Tue, Jun 28, 2011 at 9:48:36 AM | How do you chamfer two different wall types?
hcjames570
Trying to chamfer a regular curtain wall type with a basic gyp board wall type. Is this possible without an elaborate work around? Any help is appreicated. thanks
Tue, Jun 28, 2011 at 9:50:17 AM | hcjames570
hcjames570
Quoting hcjames570 from 2011-06-28 09:48:36
"sorry, this is for revit 2011
Tue, Jun 28, 2011 at 10:13:34 AM | How do you chamfer two different wall types?
What do you mean by chamfer? <<< BAD term here I think.
Do you mean join a normal wall to a CW at a 90?... at a 45? ... or at a 90 but miter the join?
Please clarify your question.
Tue, Jun 28, 2011 at 10:26:54 AM | How do you chamfer two different wall types?
hcjames570
I am trying to mitre two different wall types at a 135 degree angle. One wall is a curtian wall at 90 degrees and should stay at that angle. The other is a gwb wall and currently the curtain wall mullion is interesecting the end of the gwb wall.
I would like to mitre the end of the gwb wall at 45 degrees to the curtain wall mullion.
Tue, Jun 28, 2011 at 10:35:43 AM | How do you chamfer two different wall types?
You are still not clear because I think you are talking angles in plan and maybe elevation.  If you mean the CW ends with a normal 90 in plan and intersects a wall at an angle in plan?  Then turn off the wall joins for the CW.  And add a vertical in-place vertical void to cut the end of the drywall wall with a 45.
Tue, Jun 28, 2011 at 10:38:16 AM | How do you chamfer two different wall types?
hcjames570
You have it right. The scenario is competely in plan. I will proceed with your suggesting that the two walls wont actually be joined.
Thank you for the tip!
Foundation wall chamfer
Thu, Sep 29, 2011 at 10:58:22 AM
chamfer
Mon, Apr 7, 2008 at 4:59:25 PM
chamfer edges
Mon, Jan 18, 2010 at 11:15:46 AM
Chamfer top of foundation wall
Wed, Dec 10, 2008 at 12:14:19 PM
Embedded Angles won't chamfer
Tue, Apr 17, 2012 at 8:23:58 AM
Page generation time: 0.6202
