13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> grids
26 Posts No Rating |
Having major problems with gridlines.
Have drawn a foundation plan and lock the grids onto the slab edges no problem. In another plan wiew showing walls the walls are positioned on the grids with a 20mm overhang.
Problem is after a period of drawing the slab edges/walls move off the gridlines repeatedly. Frustrating
Any help?
Cheers
One solution -
Check your grid dimensions to make sure they are correct then select them all and pin them. Then you can use the align tool to align and lock your model elements to the grid.
I try to always have my reference lines & grids pinned.
Thx Rythmick
You are a star - worked!
Cheers
Grids at an Angle in Plan don't display in Elevation |
Thu, Apr 26, 2012 at 2:44:38 PM
new user - copying grids to other levels |
Mon, Dec 6, 2010 at 3:06:35 PM
multiple scope box for grids |
Tue, Sep 1, 2015 at 8:35:46 AM
DIMENSIONing GRIDS - on plan view |
Thu, May 26, 2011 at 1:33:19 PM
2D and 3D Grids |
Wed, Oct 17, 2007 at 10:04:13 AM
