Forums >> Revit Building >> Technical Support >> Timber Mid Rail
Mon, Jun 27, 2011 at 10:40:06 AM | Timber Mid Rail
rickzloureiro
Hi Guys,
Im using Revit Architecture 2012, does anyone know how to add a timber mid rail onto an existing timber wall, i have already created a profile for this under profiles/skirtings but only seem to load it up when i select the roof/fascia detail, problem is it sends it to the eaves height and not on the level where i have originally wanted it. The midrail is only 25mm x 160mm high which sits on the external wall 750mm up from finished floor level.
Ive attached a cad section illustrating this.
Thanks for your help
Mon, Jun 27, 2011 at 10:58:50 AM | Timber Mid Rail
4 Stars: 205 Votes
Did you tried with "Wall Sweep"?
Mon, Jun 27, 2011 at 12:15:55 PM | Timber Mid Rail
rickzloureiro
Yes thanks it worked.
Obrigado
Timber panelling 3'-0" high within room Revit 2010
Thu, Nov 19, 2009 at 1:55:35 PM
Timber Framing
Tue, May 9, 2006 at 9:04:39 AM
rail termination
Tue, Apr 8, 2014 at 10:18:59 AM
Set baluster on Bottom Rail
Thu, Mar 29, 2012 at 8:59:47 AM
dimensioning to line mid point
Wed, Aug 27, 2008 at 9:37:51 AM
Page generation time: 0.0346
