Forums >> Revit Structure >> Technical Support >> Curtain Wall & Room Bounding Dissapeared
Mon, Jun 27, 2011 at 6:18:07 AM | Curtain Wall & Room Bounding Dissapeared
HDR1978
Hi,
I am very new to Revit and am hoping there is a simple way to resolve this.
My existiing building model was completed and I was setting up my new sheet views. When opening the GF Plan view I noticed that my windows/ curtain walls & room boundings/tags had dissapeared. My origional thought was that I had accidentally deleted the elements as when trying to create a new room it was telling me there was no bounding. However, when opening my 3D view all of the curtain walling and windows are visible.
I have checked the VG, Plan cut plane and a few other basic things but nothing seems to be working (All of the above are visible on the other two floors).
I appreciate any responses in advance.
Thanks,
Huw
Mon, Jun 27, 2011 at 8:08:06 AM | Curtain Wall & Room Bounding Dissapeared
I see the term "existing" in your post.  Are you using phases?  Look at the element's phase.
Did you turn off room bounding for the CW?
Mon, Jun 27, 2011 at 9:36:36 AM | Curtain Wall & Room Bounding Dissapeared
HDR1978
Thanks for the response Hub,
I found this shortly after posting and you are correct, I had my curtain walling & room bounding in new construction. Basic error on my behalf but thanks for the reply.
Cheers,
Huw
BIG curtain wall room bounding problem!!
Mon, Dec 14, 2009 at 9:31:31 AM
Fri, Jul 28, 2017 at 4:03:50 AM
13
room bounding parameter in wall
Fri, Jun 27, 2008 at 10:17:07 AM
Room bounding...
Sat, Jan 6, 2007 at 7:39:42 PM
Ceiling not bounding room
Wed, Oct 6, 2010 at 4:01:35 PM
Page generation time: 1.1244
