Forums >> Revit Building >> Technical Support >> help with lighting fixture rendering
Sat, Jun 25, 2011 at 10:41:45 AM | help with lighting fixture rendering
barry13
hi. so i'm following this training book for a while. but its rendering instruction is awful short to being useless.
how do i achieve the rendering in picture 2.
when i render the scene, i'm gettng picture 1, the lighting fixture is just a white light without or with very little effect on the surrounding unlike in the second picture. i don't know where to find the settings, where to tweak, etc.. please help thanks
i'm sure the two scenes are similar in terms of what materials used because i followed the training book step-by-step.
Edited on: Sat, Jun 25, 2011 at 10:43:07 AM
Sat, Jun 25, 2011 at 3:30:29 PM | help with lighting fixture rendering
keyaggie
Check the material properties of the lampshade itself.
Sat, Jun 25, 2011 at 8:47:35 PM | help with lighting fixture rendering
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Your lighting seems to be working fine -- but after your render is finished, hit the "adjust exposure" button.  Here, you can toy with exposure, the light, dark, and midtones ranges, the saturation and warmth, etc.
The two values I'd suggest messing with first, is Exposure, and midtones.  Midtones will bring up a lot of the "ambient" light that's bouncing around.
Exposure usually has to be adjusted, because revit can't seem to remember or default to a particular value if you use "exterior with sun" or "interior with artificial."   The exposure values are WOLRDS apart for these two types of renderings, because the rendering engine takes the lumens/candlepower of the sun and lightbulbs literally.  I consider this a bit of a flaw, because it's difficult in revit to mesh interior lighting with outdoor views.  The sun is overpowering and makes building interiors look dark and unattractive.  The human eye adjusts. This is why we have an iris. Revit doesn't.
Lighting Fixture
Tue, Jan 8, 2008 at 7:33:08 AM
lighting fixture basic?
Sun, Oct 16, 2011 at 8:00:31 AM
The lighting fixtures wont show up in my final revit 2013 rendering.
Wed, Jul 31, 2013 at 3:23:18 AM
Removing constraints on lighting fixture families
Tue, Apr 7, 2009 at 3:57:35 PM
Linear lighting fixture
Wed, Sep 2, 2009 at 2:32:08 AM
Page generation time: 0.5346
