14 Users Online (12 Members):
Forums >> Community >> Newbies >> Using Sketchup with Revit Architecture
87 Posts No Rating |
I've been playing around with Sketchup and see how easy the modeling is compared to Revit. How well does the two programs interface with each other and is it worth getting Sketchup to do the initial design phase of the project...OR will I just end up duplicating unnecessary work. Perhaps I need to by the Sketchup Pro rather than using the free limited version
Revit and sketchup don't communicate particularly well. You're not going to have revit recognize "walls" drawn in sketchup, for example. the best you can do is import the .skp file as a mass, and revit can recognize the faces of the mass, and you can apply walls crudely to those faces.
So a lot of work would be duplicated.
I disagree that Revit is significantly slower than sketchup for modeling, though, to go back a step. It's just a matter of what program you're more proficient with. Sketchup is great for conceptual modeling, but the program gives diminishing returns the more complex your model becomes, and there's a glass ceiling well short of producing construction documents. Revit might be slower at first, but all work is cumulative, and the payoffs become greater the deeper invested in a BIM model you get.
5 Posts No Rating |
If you need conceptual design you can use Project Vasari. It's Autodesk software and free. It's fully integrated with Revit.
Sketchup to Revit |
Wed, Aug 26, 2015 at 10:41:27 AM
Sketchup model into Revit |
Tue, Jan 8, 2013 at 12:06:20 PM
SketchUp to Revit |
Sun, Mar 22, 2009 at 6:53:33 PM
Sketchup To Revit Problems *Please Help* |
Thu, Mar 12, 2009 at 9:21:29 AM
A little SketchUp with your REVIT ? [ 1 2 3 ] |
Mon, Apr 13, 2009 at 3:06:13 PM
34
