Forums >> Revit Building >> Technical Support >> Customizing Revit Templates
Thu, Jun 23, 2011 at 2:46:49 PM | Customizing Revit Templates
tkgshawn
So I've been at firms that already have a template file up and running. I am now at a smaller company and I'm trying to rehash their old "project starter file" which was overloaded with entirely too much junk. I want to start a clean template file which I will then use to create new template projects. The problem is I can't find a tutorial or published checklist to run through items to consider for new template creation. I know it will be an item requiring update from time to time but I would really like to get the first base template as good as possible. Can anyone lead me to a anything that might help?
Thu, Jun 23, 2011 at 3:03:36 PM | Customizing Revit Templates
I don't recall anything here but you have already learned an important lesson - don't bog down your template!
We only have a few basic wall types and doors.  Obviosly a few plumbing fixtures, no windows and some hatches, very common detail elements and our standard lines / callouts / sheets. Most important here is style settings.
Our Title sheet with symbols / map / sheet index .... is all set up.  We also have a door schedule sheet with schedule and door elevations... same for windows and room schedule sheet.
We have seperate library projects - one for doors, one for windows, ...detail elements, ...hatches ... wall types ... plumbing fixtures and accessories....etc.  When we start a project, we open up the wall types - goto the legend sheet and copy/paste the wall legends (which also copies the types) and place those in the projects wall legend sheet.  As we need other elements, we open the appropriate library project.
Customizing Families and objects
Wed, Oct 26, 2005 at 4:07:45 PM
Used based Revit templates
Fri, May 2, 2014 at 5:17:38 AM
Drawing templates
Thu, Jun 10, 2004 at 1:41:36 PM
revit 2014 templates is denying access
Wed, Oct 29, 2014 at 7:36:22 AM
Where have my templates gone in 2012
Sat, Apr 7, 2012 at 9:09:06 AM
Page generation time: 1.4392
