Forums >> Revit Building >> Technical Support >> Model line types not showing correctly in one floor plan
Wed, Jun 22, 2011 at 10:53:54 AM | Model line types not showing correctly in one floor plan
jennijenj3
Hi,
I'm working in 2010 Revit Architecture and one of my floor plans will not show the model lines correctly.  I'm wanting to show a hidden line for soffits above, etc, but when insterted as a model line or when I convert a drafting line to a model line the hidden line turns to a continuous line.  All other views this line shows correctly, it just this one floor plan.  I'm guessing it has something to do with the VG's of the actual floor plan view, but I cannot figure out what it is.  There are also no overrides to this particular line type within the view.
Please help.
Wed, Jun 22, 2011 at 11:11:02 AM | Model line types not showing correctly in one floor plan
Remember - model lines scale with the view.  So the spaces basically go away.   I don't believe these should ever be model lines!  For items above that you want to show, put an underlay plan that shows the items, use the linework tool to point to the soffits setting them to overhead, then remove the underlay.
Wed, Jun 22, 2011 at 11:20:28 AM | Model line types not showing correctly in one floor plan
jennijenj3
I do prefer the linework tool to show soffits above but for this project we are using model lines.
The lines scale with the view, but for some reason on this floor plan the model line scale is not working.  The scale is set to 1/8" on all the floor plan views, but on the 2nd floor they are showing continuous.  When inserted as a drafting line the hidden line shows, but when it's a model line changes to continous.  Like I stated before the are no overides on the line type.  Is there a place to veiw what the model line properties are?
Ceiling Model Lines Showing up on Floor Plan
Tue, Dec 13, 2011 at 6:04:04 AM
Window not showing up correctly in wall?
Thu, Feb 7, 2008 at 10:40:22 AM
Newly drawn model lines not showing up in Floor Plan (revit 2010)
Tue, Dec 21, 2010 at 10:06:04 AM
Help- floor pattern not showing up in plan, only model??
Sat, Apr 1, 2006 at 8:56:46 AM
Windows not showing correctly in legend
Mon, Dec 14, 2009 at 5:22:42 PM
Page generation time: 3.7982
