Forums >> General Discussion >> Revit Project Management >> Can't select elements like in 2011
Tue, Jun 21, 2011 at 10:55:14 PM | Can't select elements like in 2011
jfcarch
There seems to be a probleme to select an Highlighted element in 2012.  Clicking on the highlighted element will select the one beside.  Unchecking the hardware acceleration solve this problem howevere this option will not allow for realistic display and ambiant shadow.  Any suggestion?
Thanks
Wed, Jun 22, 2011 at 5:28:38 AM | Can't select elements like in 2011
4 Stars: 205 Votes
"Clicking on the highlighted element will select the one beside" - wierd, I don't have that problem... did you try the "TAB" key?
"Unchecking the hardware acceleration solve this problem howevere this option will not allow for realistic display and ambiant shadow." - That's true.
Wed, Jun 22, 2011 at 7:32:27 AM | Can't select elements like in 2011
jfcarch
Even with the TAB, the wanted element gets highlighted but when I click on it it's still another one this is selected.  Actually, I realised with the TAB you have to stop your cycle just before your element gets Highlighted, it is just that you have to cycle one or two time to remember what comes before your wanted element!  It might be my graphic card.
Wed, Jun 22, 2011 at 8:19:09 AM | Can't select elements like in 2011
keyaggie
I noticed the same behavior.  I have to click several times to select the item I want.  I have been keeping the hardware acceleration unchecked because of this.
I think it is the graphics card, which is a bummer since my setup is barely over a year old Sad.
select elements on current level only - revit 2014
Tue, Jul 23, 2013 at 7:52:33 AM
I can not select some elements in a file
Wed, Apr 10, 2013 at 5:28:15 PM
CAN'T SELECT GROUP
Sun, Nov 25, 2012 at 12:33:43 PM
'unable to copy elements from file' error in inserting a saved view
Wed, Jul 25, 2012 at 10:16:55 AM
Move elements vertically in Revit Architecture 2011
Tue, Aug 3, 2010 at 9:40:17 AM
Page generation time: 0.5760
