Forums >> Revit Building >> Technical Support >> Beam System Tag
Sun, Nov 20, 2005 at 11:27:17 PM | Beam System Tag
heffa
I want to be able to apply a tag to a beam system, indicating member size and spacing. I've loaded a tag from the Revit Library, but it doesn't seem to recognise a beam system as tagable. Beam System visibility is turned on, and as usual, is only visible when pre-selected. I would greatly appreciate some advice in this regard, Thanks, Martin
Wed, Nov 23, 2005 at 9:44:05 AM | RE: Beam System Tag
McGraw
I have the same problem. Could it be a bug? I get this message when attempting to create an instance: "Can't create this kind of element in this view in the current mode." Sam Spencer Auburn, CA
Wed, Nov 23, 2005 at 3:15:49 PM | RE: Beam System Tag
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I can tag the beam system... Well the individual elements of the beam system. I don't beleive you can tag the beam system itself.
Wed, Nov 23, 2005 at 4:59:29 PM | RE: Beam System Tag
McGraw
This is the generic "structural beam system tag" that installs with Revit. Sam Spencer Auburn, CA
Wed, Jun 10, 2009 at 5:22:44 PM | Beam System Tag
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
i realize that this is an old post (hopefully this will work to my advantage in this case), but i'm running into the exact same issue as McGraw.
i looked through the help file and have discovered that certain buttons and options that should be there (according to help), are not.
i simply typed "tag beam system" as my query and in the list of responses, found "taging beam systems" (a startlingly precise result i must say).  the instructions go on to explain how to load the family, and then it goes a bit wonky -
on the drafting menu, or the drafting tab of the design bar it says, i should find a button - "beam system tag"; i see no such thing, not greyed out, no fly-out... nothing.
please, can someone tell me what i'm missing?  i usually have structural plans drawn by an engineer, so this is not something that i've yet had to do and i'm sure it must be something rediculously simple.
thank you in advance,
-Ryan
Revit 2010 - It's a good thing... Stop Fighting it.
Fri, Aug 14, 2009 at 12:19:09 AM | Beam System Tag
ramirez
The Beam System Tag is only available in Revit Structure.   The Drafting tab in 2009 Revit Structure looks like:
Modify
Dimension
Spot Dimension
Text
Grid
Level
Matchline
Reference Plane
Scope Box
Keynote
Tag
Tag All Not Tagged
Beam Annotations
View Reference
Span Direction
Area Reinforcement Symbol
Path Reinforcement Symbol
Beam System Tag
Symbol
Legend Component
Detail Lines
Detail Group
Detail Component
Masking Region
Repeating Detail
Filled Region
Revision Cloud
Fri, Aug 14, 2009 at 3:09:33 AM | Beam System Tag
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
well that's just depressing.  so much for doing nice, clean, easily reviseable framing plans in RAC.  thanks for the info though.
How to tag a structural beam system?
Mon, Feb 11, 2013 at 4:04:43 PM
Automatic Beam System and Tag On Options
Wed, Nov 26, 2014 at 7:29:00 PM
Tag Beam System In section/elevation
Wed, Jul 5, 2006 at 3:56:43 PM
Beam System Tag
Mon, Feb 23, 2015 at 2:19:47 PM
Custom Beam System Tag
Wed, Jun 5, 2013 at 6:03:46 PM
Page generation time: 0.4611
