Forums >> Community >> Newbies >> Correct family template for a sheet "stamp"?
Tue, Jun 21, 2011 at 4:44:15 PM | Correct family template for a sheet "stamp"?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
I have a logo for the local county government that I'm trying to make as a family so that I can just "stamp" it onto a sheet in the correct spot when needed, rather than design it as part of a sheet template.
It consists of a filled region, text, and an imported .png picture.
I have tried using the DETAIL COMPONENT template and the GENERIC ANNOTATION template, but in the first case, I can't place it on a sheet, and in the second place, I can't even get the items to copy into the template.
Does anyone know how I can reconcile these items into one family that can be placed on top of the title block?
Thank you.
Tue, Jun 21, 2011 at 7:19:48 PM | Correct family template for a sheet "stamp"?
TKennedy
4 Stars: 8 Votes
Try a symbol family instead of a detail component, that's what we have for our logo. It can be dropped directly onto a sheet or view, or inserted in the titleblock family.
Tue, Jun 21, 2011 at 9:24:03 PM | Correct family template for a sheet "stamp"?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
Huh.  I didn't even notice that as an option.  I'll check into that tomorrow.  thanks!
Mon, Jun 27, 2011 at 1:06:17 PM | Correct family template for a sheet "stamp"?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
Where do I find the symbol family template?  I don't seem to have that.  Does it ship with RAC 2011?
Mon, Jun 27, 2011 at 2:00:51 PM | Correct family template for a sheet "stamp"?
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
I have no issue inserting (text, image, and filled region) from a generic annotation into a template file, so I am not 100% sure what your problem is
but
here is another option:
I know you said you don't want it as part of your title border but you could put into your title border and use a visibilty control to  turn it on or off for each sheet
Or
put your logo in a legend view and you can place the legend view as needed on each sheet.
The best option is to create a family, not sure why you can't get your 3 items not to work.
TKennedy:  What are you calling a symbol family?  A symbol is nothing more than a 2D annotation family inserted by the symbol button under Annotation Tab.  Am I missing something?
  • Ability is what you're capable of doing.
  • Motivation determines what you do.
  • Attitude determines how well you do it.
Quote by:  Holtz, Lou
  • Life is all about the attitude
Mon, Jun 27, 2011 at 3:41:06 PM | Correct family template for a sheet "stamp"?
TKennedy
4 Stars: 8 Votes
cadman6735: I'm fairly certain we are talking about the same thing. Perhaps adding the word family in my post was a bit superfluous.
Mon, Jun 27, 2011 at 5:08:31 PM | Correct family template for a sheet "stamp"?
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
TKennedy: It seems the OP was confussed by "symbol family" too and was looking for it.  I just wanted to be sure we all understood each other.  Thanks for the follow up.
Mon, Jun 27, 2011 at 5:10:23 PM | Correct family template for a sheet "stamp"?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
Thanks for the responses.  What I ended up doing was creating a generic annotation file, and since it wouldn't let me copy anything over from the family I had already created (since I guess in annotation families you can have sheets and not views, and vice-versa with detail component families?), I just created it from scratch as a generic annotation.  Then once that family was loaded into the project, I could use the symbol button to place it like a stamp on the sheet.
Delete "stock" Project Info. & Drawing Sheet Parameters?
Mon, Nov 23, 2009 at 4:05:40 PM
Plot stamp parameter that will read the windows file "Modified Date"...
Tue, Apr 9, 2013 at 5:54:03 PM
Calculated field on sheet to state whether "numeric" or "Alphabetic" no. used
Tue, Jul 10, 2012 at 7:07:05 AM
tagging by "family name" and "family type"
Mon, Jun 1, 2009 at 8:54:54 PM
adding a parameter to "view-title"?
Thu, Aug 2, 2007 at 4:11:24 PM
Page generation time: 1.7730
