Forums >> Revit Building >> Technical Support >> window cant tell front from back
Tue, Jun 21, 2011 at 1:33:15 PM | window cant tell front from back
Warchitect
4 Stars: 5 Votes
how can you tell which is the front or back of the window? "slider with trim" window...I cant tell....I want to take off the trim from the interior so there is no trim or sill, but it seems like the window is backwards. ie set in the wall reversed, but I cant tell the difference when I open the part and try to delete the trim.
Tue, Jun 21, 2011 at 3:41:06 PM | window cant tell front from back
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
maybe select the exterior view from the project browser?
Wed, Jun 22, 2011 at 2:28:16 AM | window cant tell front from back
mansell5
3.5 Stars: 4 Votes
hello warchitect.
load up a double hung window family, place in wall.
check 3d view and note the positioning of upper sash(should be on outside).
i placed the window with mouse pointer near the outside of the wall, and window inserted correctly.
if you are inserting generic type windows, maybe they dont have accurate sloping sills, (made with simple sweep, to all 4 sides perhaps.)
maybe duplicate one of these family and edit to provide a better sill with fall etc(also makes it easier to identify in plan view.
regards,
geoffm
Wed, Jun 22, 2011 at 4:53:19 PM | window cant tell front from back
Warchitect
4 Stars: 5 Votes
Thanks Gform,
you hit on exactly what I was asking, I guess. Also I did delete the wrong side of the window LOL.
its easy to note the double hung one, your right, the more generic ones gets a little vague.
warc.
Send to back/bring to front
Sat, Aug 13, 2016 at 2:20:22 AM
BRING TO FRONT/SEND TO BACK
Fri, Dec 9, 2011 at 7:58:01 AM
bring to front/send to back?
Fri, Jun 7, 2013 at 7:47:02 AM
WINDOW FAMILLIES
Fri, Jan 9, 2004 at 1:54:18 PM
Detail Components with Demo Objects
Tue, Dec 30, 2008 at 4:34:29 PM
Page generation time: 0.9007
