Forums >> Revit Building >> Technical Support >> project sharing
Tue, Jun 21, 2011 at 12:37:16 PM | project sharing
amber01aggie
This is what I've been taught:
To create a new central file from an old one, physically copy it in the file.  File-Open in Revit.  Detach from Central & Audit.  when the file opens, Save As (the new central file name).  And now you have the new central file.  I usually close out of the file and File-Open again to see if the prompt offers me an option to "save local file" which means to me that the process was completed properly.
This is the issue:
A co-worker presented me this file.  It was created from the out-of-box Revit template (not our standard process).  He is unable to workshare with another co-worker.  I've copied the original file over, opened with revit, but I'm never prompted to "detach from central" (aka, that option is gray).  Once opened, I've saved as a new file and closed the file.  For the check, I re-open the file and there's no option to "save local file".  when opened, there's of course no save to central option either (because it IS the central).
I'm at a loss... never encountered this one... most of the time it's just someone not "saving as" when they're supposed to.  So the file, I guess, is becoming a detached central file upon my physcially copying it?
Any suggestions?  Thanks ya'll!
Tue, Jun 21, 2011 at 12:43:08 PM | project sharing
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Two things come to mind.
First, is the file workshared enabled (Are their worksets set up and it is a central/local)?
Second, is the file an RTE or RVT?
Last I checked (many years ago) a RTE could not be workshared. If this is the case, save it as a project file (RVT) and enable worksharing.
Edited on: Tue, Jun 21, 2011 at 1:06:04 PM
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Tue, Jun 21, 2011 at 1:03:28 PM | project sharing
amber01aggie
Thank you Brett!
It's been so long since I've worked with a fresh file, I forgot there are no worksets set-up!!!!  Can't believe I didn't think of that!  Thanks for being on top of things!
Tue, Jun 21, 2011 at 2:10:29 PM | project sharing
keyaggie
Gig'em!
Tue, Jun 21, 2011 at 2:41:40 PM | project sharing
amber01aggie
Whoop!
Tue, Jun 21, 2011 at 2:41:59 PM | project sharing
brettgoodchild
4 Stars: 17 Votes
Wolverines fan myself...but love that expression!!!
Used it here a few time...(Spoken, not the literal meaning)
                             ~ Abraham Lincoln
Tue, Jun 21, 2011 at 3:03:49 PM | project sharing
amber01aggie
Aggie or not, you're allright in my book for saving the day!
Tue, Jun 21, 2011 at 3:26:57 PM | project sharing
brettgoodchild
4 Stars: 17 Votes
Just glad to help!
                             ~ Abraham Lincoln
Project Template Sharing
Fri, May 20, 2016 at 3:49:07 PM
Project Sharing Warning Message exceeded "Number of People"
Thu, Dec 3, 2015 at 7:01:51 AM
Sharing Coordinates Conceptual Mass Environment and Project Environment
Sat, Nov 16, 2013 at 10:14:00 AM
sharing notes with other projects
Sat, Dec 29, 2007 at 3:25:56 PM
Violation Sharing
Thu, May 24, 2012 at 8:33:18 AM
Page generation time: 0.9153
