Forums >> Revit Building >> Technical Support >> How do I create a Barrel Vault Ceiling
Tue, Jun 21, 2011 at 9:22:46 AM | How do I create a Barrel Vault Ceiling
NickWilliams
NickWilliams Avatar
I was wondering if anyone had any ideas on how to create a barrel vault ceiling?
I have attempting creating a barrel vault ceiling by creating a roof extrusion along the barrel vault path I desire and then editting the type to make it appear as a suspended ceiling system, but then light fixtures and other such items that require a ceiling host cannot be inserted.
Any ideas?
Thanks!
Tue, Jun 21, 2011 at 10:10:53 AM | How do I create a Barrel Vault Ceiling
You don't create this as a roof.  Create as an in-place family -CEILING category.....
Tue, Jun 21, 2011 at 11:07:02 AM | How do I create a Barrel Vault Ceiling
NickWilliams
NickWilliams Avatar
haha.  i just figured that out after playing a little.  Thanks for the help!
Fri, Apr 26, 2013 at 6:43:30 AM | How do I create a Barrel Vault Ceiling
kyxxxyk
Hi, could you please explain how did you figure this out?
Where exactly is that in-place family option?
Thanks
Fri, Apr 26, 2013 at 7:23:57 AM | How do I create a Barrel Vault Ceiling
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You your HELP, it is a good guide.  To create on its under Component>Model-In-Place
Fri, Apr 26, 2013 at 4:09:23 PM | How do I create a Barrel Vault Ceiling
NickWilliams
NickWilliams Avatar
You can create an in place family by selecting "Model in Place."  You can find this on the Home tab - Build - Component - Model in Place.  Revit will then ask you what type of family category you want to create.  In this instance, you can select Ceilings to create a ceiling.  Revit will then ask you to name this new family. Your model will then grey out allowing you to create a new family in place.  You can do so using the various different forms.  I created my ceiling using the sweep command.  The best advice, i can give.  Just play with it.  You will have to create a profile for the sweep to use and a patch for the sweep to follow.
Tue, Oct 21, 2008 at 10:12:04 AM
Barrel vault dormer opening
Thu, Jun 21, 2007 at 2:22:49 PM
Trouble with creating a Ribbed Groin Vault
Sun, Nov 25, 2012 at 12:04:44 PM
Standing Seam on a barrel vault roof
Tue, Jul 23, 2013 at 9:06:22 AM
Barrel Vault ceiling problems
Mon, Nov 22, 2010 at 4:58:04 PM
Page generation time: 2.4728
