Forums >> Revit Building >> Technical Support >> Default Template in Revit Architecture 2011 (newbie)
Mon, Jun 20, 2011 at 7:35:53 PM | Default Template in Revit Architecture 2011 (newbie)
Methisa
Im trying to start my new project but I dont understand how this works.
select the "R" button in the upper left corner of the application, new, project then the new project bar appear, I clicked ok but then it says "The chosen template file could not be found or is invalid. Please enter a different file name or choose None."
when i clicked browse there is nothing in my folder (I was expecting some provide template file)
my questions here is
      The provide template file should come with the program after I installed or do I have to downlode them separately
       What about the basic sample project or advace sameple project on the home page ( I dont have any of them!!!)
I dont really know what im doing. please anyone help me with this... thank you
Edited on: Mon, Jun 20, 2011 at 7:48:40 PM
Edited on: Tue, Jun 21, 2011 at 4:07:47 AM
Edited on: Tue, Jun 21, 2011 at 5:19:03 AM
Tue, Jun 21, 2011 at 7:00:23 AM | Default Template in Revit Architecture 2011 (newbie)
The path to your library for templates and families is set under the revit R - settings.  That shows you where Revit is looking.  If that path is incorrect, then you need to change it.
recit 2012 default template link - Rmy
Mon, Mar 3, 2014 at 7:50:02 AM
Identity Data parameters in Families not appearing in schedule RAC 2011
Fri, Jun 24, 2011 at 9:47:18 PM
Set default Room Tag
Wed, Feb 16, 2011 at 12:45:58 PM
Using 3D Studio Objects in Revit Architecture 2011
Tue, Sep 20, 2011 at 12:09:53 AM
Which Template does have Brick and CMU over MTL Stud.
Fri, Jul 15, 2011 at 3:38:08 AM
Page generation time: 1.6624
