Forums >> Community >> Newbies >> Will Revit MEP run on tihs?
Mon, Jun 20, 2011 at 7:01:54 PM | Will Revit MEP run on tihs?
bjdavies
I am thinking of purchasing the ASUS ep1212 slate PC which runs Windows 7. Was wondering if it would be adequate to run Revit MEP. Any help much appreciated.
Tue, Jun 21, 2011 at 9:40:06 AM | Will Revit MEP run on tihs?
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Will it run it, yes but it near the bottom of the required specs.
I would not necessarily look at running MEP, rather how you intend to use it.
Something like this great for out in the field. We give our supers this kind of tablet to use on site all the time. The benefit is it will allow them to be connected to our network and at anytime in the field they can pull up electronic sheets or models to look at.
If the intent is to use Revit on here in the field, I would look at getting a virtual environment setup that you connect to. This would great on the tablet since all the processing would be done on a powerful remote computer.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
MEP electrical home runs
Thu, Sep 27, 2012 at 4:05:33 AM
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
Revit MEP
Wed, Oct 28, 2009 at 10:10:40 PM
interference check
Mon, Dec 17, 2012 at 9:24:34 PM
How to Create Structural Steel in Revit MEP 09?
Thu, Apr 2, 2009 at 2:08:56 PM
Page generation time: 1.9565
