Forums >> Revit Building >> Technical Support >> Mass void
Mon, Jun 20, 2011 at 8:34:14 AM | Mass void
nirim
5 Stars: 12 Votes
Maybe it is simple but not to me. How to create void mass as in the image?
nirim
Mon, Jun 20, 2011 at 8:41:27 AM | Mass void
Looks like you already have.  Did you set what it was to cut?  Did you read your HELP on voids?
Tue, Jun 21, 2011 at 6:49:27 AM | Mass void
nirim
5 Stars: 12 Votes
What I need is the gray object (solid) to be as void to be nested  in another family to cut a solid geometry.
nirim
Tue, Jun 21, 2011 at 7:09:08 AM | Mass void
As far as I know, only hosted families can have voids that cut their host.  Otherwise the void has to reside in the family with the element to be cut.
Tue, Jun 21, 2011 at 7:40:57 AM | Mass void
nirim
5 Stars: 12 Votes
Thanks for the reply
But I am not overly concern with the cutting issue (at the moment) I simply don’t know how to build that gray object as a void. I can make it as solid by cuting the solid with a void, I then left with a solid object the shape that I need. The problem is that I need it to be a void.
nirim
Tue, Jun 21, 2011 at 7:50:56 AM | Mass void
I'm sorry but this doesn't make sense.  A void is not an object, its only purpose is to cut a solid.  Looking at your image and reversing it says to me that you simply create a void like your solid and place it at an angle like you have.  Any part of the void beyond the solid doesn't matter.....
Tue, Jun 21, 2011 at 10:22:44 AM | Mass void
nirim
5 Stars: 12 Votes
How to do that form?
nirim
Tue, Jun 21, 2011 at 10:42:47 AM | Mass void
You do it like the attached.
93965_ScreenHunter01_Jun._21_11.39.gif93965_ScreenHunter02_Jun._21_11.39.gif93965_ScreenHunter03_Jun._21_11.39.gif
Tue, Jun 21, 2011 at 10:56:11 AM | Mass void
nirim
5 Stars: 12 Votes
Thanks for the help. I don’t want to bore you but your object is nearly there but not completely   (see attached drawing).
nirim
Tue, Jun 21, 2011 at 12:59:56 PM | Mass void
4 Stars: 205 Votes
You will need to create that like a "VOID BLEND", two profiles like you can see in my attached images, set the "Work Plane" to the "sloped" ref plane and draw (in plan view) the shape, then, select the other "Work Plane" ("flat" surface - top of that mass) and draw again the same shape, select the two profiles and select create void, done...
BTW, watch the video: http://screencast.com/t/7mS6e7BK7S
Edited on: Tue, Jun 21, 2011 at 1:19:54 PM
Wed, Jun 22, 2011 at 4:22:09 AM | Mass void
#11
nirim
5 Stars: 12 Votes
Many thanks, that is grate help.
nirim
wall by face not being cut by void in mass
Wed, Jul 17, 2013 at 3:33:06 PM
Mass, radial wall by face, opening(void) problem!
Mon, Nov 11, 2013 at 12:51:10 PM
Void Mass Not Cutting Divided Surface Mass
Wed, Jan 31, 2018 at 10:19:21 AM
VOID FORM says there is no geometry to cut.... [ 1 2 ]
Wed, Dec 17, 2008 at 12:52:27 PM
19
Trying to void a spherical mass in 2012
Wed, May 18, 2011 at 1:22:23 PM
Page generation time: 1.7827
