Forums >> General Discussion >> Revit Project Management >> Large number of schedules
Mon, Jun 20, 2011 at 5:13:57 AM | Large number of schedules
matthewh75
3 Stars: 3 Votes
I'm starting to do a building 120 rooms & need to set up 'data sheets' for each space, with a separate plan, ceiling plan & elevations along with schedules for room finishes, equipment, M&E etc over several phases, this is going to mean minimum of 840 separate schedules (7 per room) as most of the parameters are not shared between types.
There apears to be no way (in R'09) of sorting schedules (apart from alphabetically) the way you sort drawings. This would be very helpful to do so that I could work without seeing the 820!
Also as I haven't set these schedules up in full yet, will it affect performance? Is there anything else I should consider (before I go mad setting them up?)
Mon, Jun 20, 2011 at 5:15:49 AM | Large number of schedules
matthewh75
3 Stars: 3 Votes
Room data sheet set up - forgot to add this before
Mon, Jun 20, 2011 at 7:26:35 AM | Large number of schedules
Although I don't like it in some instances, this may be a good candidate for making these rooms into seperate projects with all the interior data in the project and just the shell linked in.
If you did this, you could set up all your schedules and sheets for one unit then use this as a template for your other units.
Mon, Jun 20, 2011 at 7:51:41 AM | Large number of schedules
matthewh75
3 Stars: 3 Votes
I know what you mean, but I'd end up with lots of linked projects & potentially lose the printing / coordination benefits. I was hoping to be able to coordiate all the ceiling layouts & M&E in one place. I think the main issue is not being able to filter schedules in the project browser, I'll have to scroll through them each time!
This hasn't been changed in future releases has it, we do a lot of data sheets & it would be a very handy function?
Mon, Jun 20, 2011 at 9:00:29 AM | Large number of schedules
Simply name the schedule so that they sort - then put the correct name in the Schedule itself.
Mon, Jun 20, 2011 at 12:56:18 PM | Large number of schedules
BTW ... set up one set of schedules then just copy for all the others and change your filter.
Combining Room Schedules and Area Schedules into one Large Schedule
Thu, Jan 3, 2013 at 10:57:33 AM
schedules show up on sheets too large?
Fri, Apr 21, 2006 at 6:09:20 PM
Uploading a large number of families to newer versions
Mon, Feb 19, 2024 at 5:11:38 PM
Schedules on multiple sheets
Thu, Apr 27, 2006 at 11:01:59 PM
Revit 2012 Schedules - Filter by DETAIL NUMBER
Tue, Sep 11, 2012 at 12:25:19 PM
Page generation time: 0.5071
