23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> window tag show type not number
Sun, Jun 19, 2011 at 11:49:01 AM | window tag show type not number
Warchitect
4 Stars: 5 Votes
my current window (slider with trim) tags they "type" into the little hexagon tag, instead of placing the simple instance number (ie. window no: 1,2,3,4,etc..) how do I edit the familly to show the number not the type?
Sun, Jun 19, 2011 at 3:34:53 PM | window tag show type not number
revitlink
revitlink Avatar
Hello Warchitect,
From what I understand you want to change it so each window has a tag that corresponds with its individual number.  To accomplish this:
1. Click on one of the hexagon tags you want to change
2. Click 'Edit Family' on the ribbon above and it should open the editor
3. Click on the tag again in this new window and click on 'Edit Label'
4. Remove the 'Type Mark' Parameter Name and replace it with just 'Mark'
5. Click OK to finish editing then load it back into the original project with 'Load into Project'
That should give each window a unique number. Tell me if that works for ya.
Check out http://revitlink.com for free Revit tutorials and other resources
Sun, Jun 19, 2011 at 6:05:44 PM | window tag show type not number
Warchitect
4 Stars: 5 Votes
thanks got it!
Window Tag
Wed, Jun 10, 2009 at 12:30:14 PM
Combining Door & Window Schedule; it WORKS!
Wed, Jan 20, 2016 at 10:15:28 AM
To Window Tag or not to Window Tag...?
Thu, May 21, 2009 at 12:33:24 PM
What type of window are these????? HELP~~
Sun, Feb 19, 2012 at 2:47:53 AM
Door Tag Parameter-Need it to be the door opening number, not the door type.....
Thu, May 7, 2009 at 4:09:39 PM
Page generation time: 2.1277
