Forums >> Revit Building >> Technical Support >> Room separation lines affect lower level walls
Fri, Jun 17, 2011 at 10:35:03 AM | Room separation lines affect lower level walls
sroreilly
R2011
I've been finding that when I put a room separation line on my main floor level, it is affecting the walls of the floor below.
If I move the room separation line, the wall on the level below moves as well.
In searching for an answer in forums, it seems that perhaps this has something to do with my levels, or perhaps how the walls are.... But, I've checked, & the walls below are not attached to the floor above.
This happened in another drawing, and I ended up deleting the separation line (& room), moving the lower wall back to where I wanted it, then re-drawing the separation line & re-labelling the rooms. Too much extra effort!
Has anyone else had this problem, & what does anyone think that I am doing wrong?
Susan
Room Separation Lines showing up from lower levels as halftone
Wed, Dec 22, 2010 at 12:17:20 PM
Room Separation Lines won't display [ 1 2 ]
Mon, Feb 19, 2018 at 2:00:11 PM
15
room bounding not recognizing room separation line [ 1 2 ]
Thu, Aug 18, 2016 at 10:02:14 AM
16
Room Separation
Sat, Nov 3, 2007 at 3:19:41 PM
Hide Room Separation Lines
Mon, Feb 19, 2018 at 2:03:50 PM
Page generation time: 3.4836
