Forums >> Revit Building >> Technical Support >> Select all instances - finding the one
Fri, Jun 17, 2011 at 8:32:24 AM | Select all instances - finding the one
goodriws
I am in the company's Revit Structure 2011 template and I have about 100+ drafting views created for my standard details.  They were drawn by someone who used the Centerline annotation symbol, but we don't like it.  We prefer "CL".  So an intern recently went through every view and deleted the symbol and replaced with "CL".  However, he missed one.  I am able to go to the PB and select all instances, but I don't want to just delete it, I want to go to that Instance to replace it with "CL".  Is there a way to do that?  Thanks in advance.
Fri, Jun 17, 2011 at 9:20:15 AM | Select all instances - finding the one
TKennedy
4 Stars: 8 Votes
Check it's instance properties when you have it selected. It's workset should be the view it is placed in.
Fri, Jun 17, 2011 at 9:34:28 AM | Select all instances - finding the one
goodriws
When I have the Centerline Symbol selected, my Filter shows "1" but the Properties palette is empty.  I guess that Symbol doesn't have any instance properties.  Did you try this method and it worked?  If so, I apologize, but where did you see the Workset and View Title?  It's not showing where I thought it would, in the Properties palette.
Fri, Jun 17, 2011 at 9:45:55 AM | Select all instances - finding the one
TKennedy
4 Stars: 8 Votes
I tried it on a different symbol I happen to have in my open project. It's a generic annotation, but it is placed in a drafting view.
Edit: I just loaded and placed the centerline symbol and it's still working for me. I attached an image showing where I found the info.
Edited on: Fri, Jun 17, 2011 at 9:48:34 AM
Fri, Jun 17, 2011 at 10:00:19 AM | Select all instances - finding the one
goodriws
OK, thanks.  My Properties palette doesn't have that information, for some reason.  I guess my Symbol family is different from yours.  I definitely wouldn't have started this thread if it was that easy.  Sorry to bother.
Fri, Jun 17, 2011 at 11:36:27 AM | Select all instances - finding the one
TKennedy
4 Stars: 8 Votes
Sorry, that's all I have seen that will identify a view. The only other thing I can think of is to create a group, then see if the group instance properties shows the workset.
Fri, Jun 17, 2011 at 12:32:45 PM | Select all instances - finding the one
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Is the "CL" an annotation family?
If so, then perhaps I am missing something here, but I do exactly what you are talking about w/o going to the view (most of the time).
Once you have it selected from the project browser, you can just change you selection in the type selector...should really be no need to go to the actual view it is in...though this does not always work.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Fri, Jun 17, 2011 at 1:07:15 PM | Select all instances - finding the one
goodriws
The Centerline symbol would be in front of a text box that contains "Column" or something like that so it's like CL Column.  I wanted to get rid of the symbol, but then add CL to the beginning of the text box, then move it over a bit.  So, no, the new "CL" is not a symbol.  That's the problem.
Thanks though!
Sat, Jun 18, 2011 at 6:50:32 AM | Select all instances - finding the one
coreed
coreed Avatar
4 Stars: 16 Votes
just curious, how do you know he missed one.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, Jun 18, 2011 at 8:13:20 AM | Select all instances - finding the one
goodriws
When I go to delete the Family from the PB, it tells me there's one instance that will be deleted.
Finding "Select All Instances in Project"
Fri, Oct 30, 2015 at 12:42:39 PM
select all instances??
Fri, Feb 6, 2009 at 7:36:04 AM
SELECT ALL INSTANCES
Fri, Jun 6, 2008 at 10:54:52 AM
Find objects in views using "Select All Instances in View"
Tue, Sep 3, 2024 at 5:10:21 AM
Select All Instances does not actually show all instances
Thu, Mar 28, 2013 at 1:38:37 PM
Page generation time: 0.2146
