Forums >> Revit Building >> Technical Support >> Quick and easy one...
Thu, Jun 16, 2011 at 11:31:05 PM | Quick and easy one...
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
How do I make make my roof line show up dashed on floor plan?
I have put my underlay on level 1 to show my roof but its not dashed.
http://screencast.com/t/FHF55o2LYs
Revit 2018........
Fri, Jun 17, 2011 at 12:02:35 AM | Quick and easy one...
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Also can I have an existing hip roof then for proposed change the outline without altering the existing outline?
Revit 2018........
Fri, Jun 17, 2011 at 7:48:18 AM | Quick and easy one...
Dafpfy
3.5 Stars: 11 Votes
Select roof / right click / overide in view by element / override the projection lines.
or you could just use the linework tool.
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Fri, Jun 17, 2011 at 7:49:32 AM | Quick and easy one...
"....change the outline without altering the existing outline?"  < That's an oxymoron....
A couple of possibilities.
  1. Design options.  Have two different roofs - 1 in each DO
  2. Uses phases that show demolished and new work.
You can read about both of these processes in your HELP.
To answer your first question, please read this topic in your HELP: Changing Line Styles for a View Underlay
Fri, Jun 17, 2011 at 9:00:53 AM | Quick and easy one...
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Thanks heaps guys. The right click was so much easier than what I was trying. I had to show the whole roof as being demolished but as its dashed anyway doesnt matter.
Revit 2018........
Fri, Jun 17, 2011 at 4:06:29 PM | Quick and easy one...
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
in VG, you can override roof projection lines, line type, hidden.
also, if you want your roof to show up, and not the rest of the view that's underlayed, you could use a plan region that just clips a bit of the roof, which will make all of the roof appear.  Plan regions do not print.
Fri, Jun 17, 2011 at 7:43:42 PM | Quick and easy one...
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
So I can use plan region to hide parts of the roof I dont want to see,  Thanks ill give it a go. Thanks for your help much appreciated.
Revit 2018........
Sat, Jun 18, 2011 at 7:17:48 AM | Quick and easy one...
Not sure what your last question is.  If you had read the Help item I pointed you to, you would see that you can selectively show items above your cut plane in floor plans by:
  1. Use an underlay of the roof plan
  2. Use the linework tool to pick what lines you want to show from the underlay and the linetype you want
  3. REMOVE THE UNDERLAY!
If your question is about a roof plan, you can use masking regions for large areas, linework tool (including invisible lines) and you can over-ride graphics in view.
Sat, Jun 18, 2011 at 11:10:50 PM | Quick and easy one...
latemore
latemore Avatar
3 Stars: 2 Votes
in my practice we place another view over the plan, as taught by mr spot.  it only contains roof (or whatever you want 'above'), in wireframe, with overrides for lines to be dashed.  so if you change anything, no need to update your linework.  just watch it if you move one view.  we also do this for framing layouts - and usually have three views.  say for roof framing, bottom one is walls, middle one is structure, top one is roof outlines.  they usually need different view ranges you see.  the key to this is something mr spot showed us a while ago - use revit's considerable abilities to reduce drafting.
Sun, Jun 19, 2011 at 6:04:44 PM | Quick and easy one...
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Thanks for your help guys I'll save the thread and give it a try. I have done a short course in revit which was very short and missed out on alot. Thanks again for your help much appreciated.
Revit 2018........
offering pay to complete quick easy project half way done
Fri, Apr 25, 2014 at 12:33:40 PM
Looking for quick easy square footage calculator
Mon, May 19, 2014 at 10:49:34 AM
Easy way to turn off all but specific sections?
Thu, Jan 21, 2010 at 1:59:00 PM
Hopefully a few easy things..
Thu, Aug 21, 2008 at 6:02:05 AM
Print Icon on Quick Access Toolbar
Wed, Oct 29, 2014 at 6:27:05 AM
Page generation time: 1.0136
