9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> how to view a toposurface with thickness in a elevation ou in a 3d view??
40 Posts No Rating |
in 3d view and elevations , the site toposurface apears omly "surface" !!!!!.
how have a site witk tickness , like showing a block of terranin?
and not only a sheet of terrain..
thanks a lot
For 3D views, if you use a section box and if the section box cuts the topography, it will then have thickness.
thanks a lot . fantactic!
can put some layes on toposurface similar to floors ?
You can split a topo face and assign different materials like grass / water / earth / asphalt.....
You can also draw subregions. subregions allow you to draw regions that you can select and give different materials to. The upside for subregions is that it doesn't make separate toposurfaces, and changes to your topo won't leave gaps and holes.
I thinked about layers horizontaly...
No, not really. Revit hatches in earth below toposurfaces, down infinitely.
Often in a section it's easier to draw your cut topo as a filled region rather than fuss with the actual topography.
Toposurface thickness? |
Tue, Jan 24, 2012 at 9:55:03 AM
Large Toposurface and File Size |
Fri, Aug 29, 2008 at 10:15:18 AM
Thickness for toposurface |
Wed, Jan 3, 2007 at 11:47:22 AM
Hiding View Name in Elevation View Tags |
Fri, Jan 21, 2011 at 6:47:39 PM
Flat Toposurface |
Thu, Aug 3, 2017 at 8:58:49 AM
