Forums >> Revit Building >> Technical Support >> parking spaces placed on ramps
Sat, Nov 19, 2005 at 9:12:43 PM | parking spaces placed on ramps
frs8
I am trying to create a parking garage. I did this using the ramp comand, but now I want to show the parking spaces. Is there a way to have the parking spaces appear along the ramps (i.e. incline as the ramp inclines)? Thanks, frs8
Sun, Nov 20, 2005 at 3:56:39 PM | RE: parking spaces placed on ramps
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Parking spaces can only be hosted by floors and topography... You would need to create a floor.
Sun, Nov 20, 2005 at 4:24:09 PM | RE: parking spaces placed on ramps
frs8
Can you make a sloping floor?
Sun, Nov 20, 2005 at 5:43:03 PM | RE: parking spaces placed on ramps
eldados
eldados Avatar
4.5 Stars: 8 Votes
yes you can. create your floor and while in sketch place a slop arrow, click on the arrow and go to properties, define the slop using a fall or define height for tail and head... HTH
Integrator
KarelCAD
Wed, Aug 29, 2007 at 3:23:39 PM | parking spaces placed on ramps
rwilson
So, I've discovered how to place parking stalls on a ramp, but I haven't found how to place multiple stalls without rehosting each stall onto the ramp plane (very time consuming).  Any ideas on how to do this?
Multiple Parking spaces - line based family, need help
Tue, Jul 29, 2014 at 4:34:35 PM
11
Tag for Parking Areas- lot # and total spaces in lot
Thu, May 22, 2014 at 10:37:14 AM
Labeling/Annotating Parking Spaces
Fri, Feb 8, 2008 at 1:42:41 AM
Attach Walls to Ramps
Fri, Feb 18, 2011 at 6:45:16 AM
Parking Deck
Sun, Nov 20, 2005 at 5:33:39 PM
Page generation time: 1.6493
