19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> how to make a recess celling for rope light
5 Posts No Rating |
i am trying to make a recess in the celling for rope light, also how would you go about making the tray for the rope light?
Thanks chris
well, you could make a model-in-place family (a void) in the ceiling category that cuts a channel out of your ceilings. Do you have a rope light family to use? because that sounds complicated.
i am not sure how well light-source families work within nested families, but you could try nesting a couple of families together (line-based generic model, light source, ceiling-hosted generic model) to get an all-in-one solution.
If you are not familiar with family editing, you might check Autodesk seek to see if there is any content there, as well as the Revitcity.com download section.
The get-it-done-now solution itsmyalterego suggested will work fine. Just make sure you select the right category (maybe your ceiling is actually part of your floor slab.)
As for a rope-lighting family, you can probably just modify the light-source family to mimic a rope-light effect.
Rope Lights Revit MEP 2012 |
Tue, Nov 29, 2011 at 12:10:11 PM
trying to make custom light fixture w/ 2 light sources - need help |
Mon, Jun 22, 2009 at 6:23:45 AM
Ceiling recess light/cup |
Mon, Nov 30, 2015 at 9:55:26 AM
recess in Curved Wall |
Wed, Jan 19, 2011 at 4:10:03 PM
how do i make a light shine a different colour? |
Tue, May 27, 2008 at 7:21:38 AM
