Forums >> Community >> Newbies >> Change floor color?
Wed, Jun 15, 2011 at 1:29:42 PM | Change floor color?
jps58000
I am currently working on drawing a parking lot.  The easiest way I knew to draw it was drawing a floor.  So, I have my generis 12" floor but can't figure out how to change the color.  I thought if I made it a solid fill and color it black, that it would work.  Any suggestions on how to change my floor color?
Thanks
Wed, Jun 15, 2011 at 1:47:01 PM | Change floor color?
An easier way (if you don't need to model the thickness) is to split the face of the site and change the properties of that portion of the site to site-asphalt.  Using a floor is ok, just set the floor material properties to site-asphalt.
how do you get different colors for same type of floor?
Fri, Dec 10, 2010 at 5:40:02 AM
2011 change material color [ 1 2 ]
Sat, Aug 31, 2013 at 8:46:22 AM
16
Change color on linked workset
Tue, May 16, 2017 at 6:42:49 AM
Material Color Change not Rendering (...but Old one does)
Thu, Mar 6, 2008 at 8:38:56 AM
how to change the default ground color ?
Thu, Feb 26, 2009 at 8:24:47 PM
Page generation time: 0.7404
