Forums >> Revit Building >> Technical Support >> Cutting a section through a mass
Wed, Jun 15, 2011 at 12:21:34 PM | Cutting a section through a mass
Ingeriam
I created a mass in Revit 2011, using the mass in place tool.  When I cut either a section or take a level 1 plan view it doesnt cut the mass, I see the mass a id it were an elevation.
Any ideas?
Thanks, Austin
Wed, Jun 15, 2011 at 12:23:28 PM | Cutting a section through a mass
That is correct, a mass does not cut.  Other families do not cut as well.  You can learn what cuts by searching your help using cuttable as your search word.
Wed, Jun 15, 2011 at 1:01:10 PM | Cutting a section through a mass
Ingeriam
Is there any way that I can convert all these masses into a cuttable family?
Wed, Jun 15, 2011 at 1:07:07 PM | Cutting a section through a mass
I have to smile here... I keep telling users to be careful when using masses.  Always use Revit elements if you can.
You might try exporting to 3D CAD and importing that into a cutable family.
I really don't know because I rarely use masses.
Wed, Jun 15, 2011 at 2:32:34 PM | Cutting a section through a mass
Ingeriam
What do you mean by Revit elements?
After messing around for a while I did find a way if you have any future users that have the same problem, You have to edit the mass and then throught there you click on the "family catagorie and parameteres" button.  That lets you choose what family you want the mass to be in, I just moved all my masses into the Casework catagory.
Thank you for your time and help.
Sat, May 16, 2020 at 4:21:54 AM | Cutting a section through a mass
Oliv998
Another way would be to finish mass than select wall by face to turn the masses into an elemnt so you can cut through it, although it may be troublesome if you have too many faces, but hope this helped.
FLOOR CUTTING OUT WALL MASS?
Tue, Jun 27, 2006 at 2:31:39 AM
Cutting irregular openings in curved walls
Sun, Apr 9, 2006 at 7:45:39 PM
Void Mass Not Cutting Divided Surface Mass
Wed, Jan 31, 2018 at 10:19:21 AM
Section cutting a family?
Thu, Jan 11, 2007 at 3:30:49 AM
In Place furniture not cutting
Wed, Oct 21, 2009 at 4:55:11 PM
Page generation time: 3.4424
