Forums >> Revit Building >> Technical Support >> Detail levels
Sat, Nov 19, 2005 at 12:19:49 AM | Detail levels
jyothi
hai, I have a wall whish as got 5 differnt layers, structure,sheating,finishes etc. i have created all these layer.i want all the layers to be seen in fine level, and when i set it as medium or coarse i want only 2 layers to be seen structure and finish layer. how do i do that? i tried settings in detail levels but dint work. can anyone help? Thanks, regards
Sun, Nov 20, 2005 at 4:00:07 PM | RE: Detail levels
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Revit sets it up so that at medium and fine detail levels it will show all the layers. At coarse it shows it as one element (1 layer). This behaviour cannot be changed.
Multiple detail levels of walls in same view
Fri, Nov 28, 2014 at 9:51:04 PM
Can I set text visibility to hide/show at different view detail levels?
Tue, Sep 15, 2009 at 6:56:43 AM
how to draw objects in the right scale?
Sun, Apr 10, 2005 at 9:38:18 PM
a question about detail levels..i guess
Thu, Oct 14, 2010 at 2:04:03 PM
section mark across many levels
Mon, Aug 13, 2007 at 10:07:26 AM
Page generation time: 0.3169
