Forums >> Revit Building >> Technical Support >> Shadows & Cut Planes
Tue, Jun 14, 2011 at 5:57:13 PM | Shadows & Cut Planes
tomsheridan
I have a problem with shadows. When I turn them on in plan views, the shadows are cast from the cut plane of the view. What I'm trying to do is show the client how much shadow there will be in a room at different times of the days i.e. sun studies. Is there any way to have your cut plane at 1200mm above finished floor level but have the shadows cast at full height/length?
Tue, Jun 14, 2011 at 10:06:38 PM | Shadows & Cut Planes
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
in properties of the view you can set the cut plane to whatever you need, seek on google, help menu and on this forum about cut plane.
Tue, Jun 14, 2011 at 11:05:33 PM | Shadows & Cut Planes
tomsheridan
Yes I know, but what I'm asking is if I can have the cut plane at one height and the cast shadows coming from the actual height including the shadows that would be cast by the ceilings & roofs above?
Wed, Jun 15, 2011 at 12:24:13 AM | Shadows & Cut Planes
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
i think there is  plugin that allows you to do that (like a shadow mapped on the ground)... i doubt it can be done with revit "out of the box" tools, when i remember the name i post
Would like shadows to appear from above cut plane
Wed, May 2, 2012 at 1:22:44 PM
Windows & cut planes
Fri, Aug 10, 2007 at 3:24:30 PM
Some trees not casting shadows
Thu, Oct 16, 2014 at 10:55:22 AM
Shadows on floor plans
Sat, May 18, 2013 at 7:41:40 PM
Shadows on plan view cast from cut plane
Wed, Sep 24, 2008 at 9:24:32 AM
Page generation time: 0.9485
