Forums >> Revit Building >> Technical Support >> Revit 2012 Ribbon problem
Tue, Jun 14, 2011 at 1:11:56 PM | Revit 2012 Ribbon problem
LIZARD2806
3.5 Stars: 7 Votes
Has anyone seen this before and have a solution?  I just installed Revit 2012 on a new Dell M6600 laptop with an nVidia Quadro 400M (hoping it isn;t the graphics card, but it is too new to have been approved my Autodesk, apparently).  Windows 7 64 Bit.  The quick access toolbar and help/online toolbar (above the ribbon) do not display correctly.  I can move the QAT to below the ribbon and it's fine, but I don;t want it there and I don;t see an option to move the other bar down, so the problem still exists.  Thanks for looking.
What I tried:
Turning off the transparency setting in Windows (made it worse)
Changing color of window borders (this was the best of the colors)
Running in compatibility mode for Vista.  No change.
Edited on: Tue, Jun 14, 2011 at 1:12:52 PM
Edited on: Tue, Jun 14, 2011 at 1:13:29 PM
Edited on: Tue, Jun 14, 2011 at 1:19:36 PM
Edited on: Tue, Jun 14, 2011 at 1:34:59 PM
Edited on: Tue, Jun 14, 2011 at 1:38:39 PM
Edited on: Tue, Jun 14, 2011 at 1:40:16 PM
Edited on: Tue, Jun 14, 2011 at 1:44:11 PM
**Using Revit Architecture 2009, 2011, and 2012**
Tue, Jun 14, 2011 at 1:17:32 PM | Revit 2012 Ribbon problem
LIZARD2806
3.5 Stars: 7 Votes
Sub 500kb Images refuse to upload for me today...
Tue, Jun 14, 2011 at 1:21:24 PM | Revit 2012 Ribbon problem
LIZARD2806
3.5 Stars: 7 Votes
trying Internet explorer to upload.
Tue, Jun 14, 2011 at 1:21:53 PM | Revit 2012 Ribbon problem
4 Stars: 205 Votes
testing... with Mozilla 3.6.17
395K
Edited on: Tue, Jun 14, 2011 at 1:29:08 PM
Tue, Jun 14, 2011 at 1:27:05 PM | Revit 2012 Ribbon problem
LIZARD2806
3.5 Stars: 7 Votes
Trying again...maybe it's the computer!!!  I should have got an Apple! Smile
Tue, Jun 14, 2011 at 1:44:58 PM | Revit 2012 Ribbon problem
LIZARD2806
3.5 Stars: 7 Votes
different computer.....
Tue, Jun 14, 2011 at 1:47:15 PM | Revit 2012 Ribbon problem
LIZARD2806
3.5 Stars: 7 Votes
LAST TRY....I GIVE UP AFTER THIS.  REDUCED FILE SIZE TO 25KB.
Tue, Jun 14, 2011 at 1:48:46 PM | Revit 2012 Ribbon problem
4 Stars: 205 Votes
Did you tried with different "Browser"? I use Mozilla 3.6.17 and works fine.... But I already reported this issue to ADMIN
ohhh you post that but the image is too small
Edited on: Tue, Jun 14, 2011 at 1:50:08 PM
Tue, Jun 14, 2011 at 2:03:27 PM | Revit 2012 Ribbon problem
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I've seen this uploading issue -- it's jpegs in particular that get kicked back, and from certain computers.  I cannot upload jpgs from home sometimes, though PNG and BMP work as image formats, even though they're monsters, size-wise.
Tue, Jun 14, 2011 at 2:06:01 PM | Revit 2012 Ribbon problem
LIZARD2806
3.5 Stars: 7 Votes
Typhoon...thanks for the help.  I tried on chrome and internet explorer on the new computer and chrome on the old.  Maybe the maximum file size changed?  Anyway...after all that, I went back into Windows 7 settings and changed the the theme to windows 7 classic.  It had been on an Aero theme.  That was the fix.
revit 2012-contextual ribbon tab not show
Thu, May 30, 2013 at 2:45:26 AM
revit architecture 2012 missing ribbon tabs
Tue, Sep 17, 2019 at 8:13:49 AM
ribbon issues
Thu, Aug 27, 2015 at 10:14:04 AM
can not edit anything in 3d using revit 2012
Mon, May 26, 2014 at 7:18:03 PM
RAC 2012 Modify Tab on Ribbon
Thu, Jul 5, 2012 at 10:27:41 AM
Page generation time: 1.6980
