Forums >> Revit Structure >> Technical Support >> Execute Journal File through Batch File
Tue, Jun 14, 2011 at 7:39:04 AM | Execute Journal File through Batch File
emgeeo
3.5 Stars: 7 Votes
Looking for the code to run a journal file through a batch file.
I would like it to do the following.
1.  Execute Revit with Journal file(directory location)
2.  Delete Journal Files
3.  Exit Batch
I can't find much help on the web.  Surely, someone here knows how to do this.
thanks you in advance.
Tue, Jun 14, 2011 at 8:30:05 AM | Execute Journal File through Batch File
emgeeo
3.5 Stars: 7 Votes
Really, I just need to know how to execute Revit with a journal file.
Tue, Jun 14, 2011 at 8:56:21 AM | Execute Journal File through Batch File
coreed
coreed Avatar
4 Stars: 16 Votes
drag the jounal file and drop it on top of your Revit Desktop icon is one way
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Jun 14, 2011 at 9:43:14 AM | Execute Journal File through Batch File
emgeeo
3.5 Stars: 7 Votes
Drag and Drop is the behavior I am trying to mimic with the batch file.
I have used this in the past at an A+E firm where the Architects were using AutoCAD and the Engineers were using Revit.  Using a batch file was our way of keeping .dwg drawings current.  Essentially we created a journal file which opened the central file detached, exported pre-selected views to autocad, and closed the program.
We then executed the journal file with a batch file.  The batch file ran the journal file, deleted any newly created journal files, and shut the computer down when it was done.
I need to know how to EXECUTE A JOURNAL FILE WITHIN A BATCH FILE.
Thu, Jun 16, 2011 at 2:33:14 AM
Revit 2012 - Try to recover rvt file from Journal Files
Mon, Jun 25, 2012 at 12:16:27 PM
ARGHHHHH....lost file. Found journal txt file though
Mon, May 5, 2008 at 7:07:46 PM
Revit Family Batch Updater - Anything like this?
Wed, May 12, 2010 at 6:03:46 PM
Massive file slow down
Fri, May 2, 2014 at 3:03:24 PM
Page generation time: 0.4959
