24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Material orientation issue on structural framing
1 Posts No Rating |
Hi all,i have the case where the same material runs in opposing directions on the same structural framing objects - say a pitching beam with a hardwood map running along its length ( horizontally ) in one instance and then it will run vertically in another. it doesnt seem to matter if the object is copied or placed individually and appears to be totally random and it makes my renders useless really .When you trim objects together sometimes the map will run horizontally, other times vertically. it also doesnt matter what material you use, the behaviour is the sameany ideas appreciated,cheers geoff
12 Posts No Rating |
I am actually having the same issue with architectural framing. The same wall type with an image seems to rotate that image randomly. I'm still searching for a solution but if I find anything that may be relevant I'll post up.
structural framing family cut pattern interacting with wall in section 2017 |
Wed, Sep 5, 2018 at 12:52:56 AM
Copying Structural Framing to Other Floor. |
Mon, May 11, 2015 at 11:32:27 AM
Structural Framing Plans/Callout Beam Sizes |
Wed, Feb 22, 2006 at 5:49:10 PM
Structural framing tag |
Mon, Apr 5, 2021 at 1:29:32 PM
Structural Framing Tag |
Tue, Feb 26, 2008 at 10:27:24 AM
