Forums >> Revit Building >> Technical Support >> Convert roof to Mass?
Mon, Jun 13, 2011 at 6:06:46 PM | Convert roof to Mass?
bcthompson
bcthompson Avatar
Hi guys,
I'm playing around in Revit Arch 2011 with curved roofs created from extrusions, and I'd like to convert these to generic masses so that I can make curtain walls from the faces. I could swear I've done it before, but maybe not. Will I just have to build the masses as extrusions with the same dimensions as the roofs and delete the originals?
Thanks!
Brendan Thompson
CAD Drafting - 3D Viz - Graphic Design
www.bct3d.com
Mon, Jun 13, 2011 at 7:05:24 PM | Convert roof to Mass?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
yep -- edit your family, and up in the upper left you'll see an icon appear with a manila folder, called "family category and parameters"  Hit that, and you can redefine it with your choice of categories.
Tue, Jun 14, 2011 at 10:56:58 AM | Convert roof to Mass?
bcthompson
bcthompson Avatar
Thanks, although it looks like since roofs are a system family I can't edit them in the usual manner. I'm looking around on the ADSK forums and I'll let you know what I find out :-)
Brendan Thompson
www.bct3d.com
Tue, Jun 14, 2011 at 12:05:44 PM | Convert roof to Mass?
itsmyalterego
4 Stars: 16 Votes
Oh... When I saw "extrusions" I thought you meant you created it as an in-place family with extrusions, not created a roof by extrusion... Subtle semantic difference, but your roof can't leave the roof category the way you've done it. Upside is that you can make face-based families that don't care about the category, if you're adding skylights or something of that nature. But if you're replacing large swaths of it.. You might have make a new family I think, for your roof.
Tue, Jun 14, 2011 at 12:10:34 PM | Convert roof to Mass?
bcthompson
bcthompson Avatar
Thanks for the response, I think you're right. Luckily I'm not too far into the project, and even more luckily it's just a personal thing on my free time so there are no deadlines :-) I guess the lesson to take from this is that it's real easy to convert masses to walls / roofs etc, but not the other way around... Cheers!
Brendan Thompson
www.bct3d.com
Roof by Face on curved mass surface issue
Mon, Oct 5, 2015 at 12:39:58 AM
construct free forms
Tue, Sep 21, 2004 at 12:48:07 PM
Mass Roof not working
Mon, Mar 3, 2014 at 7:51:52 AM
Reverse the face of mass for roofing
Sun, Dec 14, 2014 at 12:21:36 AM
Roof by Face and Wall by face tools
Tue, Jan 28, 2014 at 6:31:03 AM
Page generation time: 0.3329
