Forums >> Revit Building >> Technical Support >> Light Fixture Families
Fri, Nov 18, 2005 at 12:46:02 PM | Light Fixture Families
chawley
I am trying to edit a light that I found in the RevitCity family explorer (Schoolhouse_Light_2111.rfa). From what I can tell it seems to be a fixture with no light. I tried rendering a room with a bunch of these lights and its dark (I did have all the lights turned on) Do I need to specify a line as a light emitter? If so how? Can I specify a solid extrusion a light emitter. Any help would be much appreciated. Thanks Chuck
Fri, Nov 18, 2005 at 4:51:18 PM | RE: Light Fixture Families
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Check the family the lighting point might have been placed above your ceiling or something... Best bet is to use studio lights located directly below you lighting fixtures at head height and use these to illuminate the room.
Opaque light fixture not emitting light
Wed, Dec 18, 2013 at 3:30:34 AM
Understanding Light Fixture Families
Mon, Jul 9, 2007 at 9:34:20 AM
Light fixture doesn't produce light
Sat, Jun 7, 2008 at 12:39:38 PM
One light fixture, two circuits?
Mon, Jul 14, 2008 at 9:18:24 AM
Lighting fixture not showing ANY light
Fri, Apr 10, 2009 at 12:30:55 PM
Page generation time: 3.1967
