Forums >> Revit Building >> Technical Support >> Arc Lines display as straight lines
Fri, Jun 10, 2011 at 3:29:09 AM | Arc Lines display as straight lines
jawii
Hi.
I have experienced problems with arc lines in 2D drawings, especially in window profiles when I have multiple arcs on one or more profiles. When I draw the profile and arcs, everything works just fine, but then at some point the arc lines are replaced by straight lines that tangent the arc.
At first I thought it had to do with some graphic compensation, and that the arcs would print out just as they were drawn, but unfortunately thats not the case.
I create profiles as .rfa std., and in the profile family there are no problems with the arcs. But as soon as I load it into my window family the lines convert ? - Note that in 3D mode the lines look just perfect, and there is nothing wrong with the shape except in section/plan/front views.
Ofcourse checked all my view settings and so on, detail levels etc., but can't see what I'm missing.
I hope some of u guys can tell me what I'm doing wrong.
BR/
Jacob Wiinholt
Fri, Jun 10, 2011 at 4:59:06 AM | Arc Lines display as straight lines
jawii
BTW: I'm using Revit Architecture 2011
Edited on: Fri, Jun 10, 2011 at 4:59:59 AM
Fri, Jun 10, 2011 at 11:44:07 AM | Arc Lines display as straight lines
This looks like the arc element might be just too small.  Did you import this from CAD by chance?
Fri, Jun 10, 2011 at 12:46:31 PM | Arc Lines display as straight lines
jawii
No I made the profiles af families and applied to my window family.
The profiles / arcs looks just fine when I open the profile family (attached)
Fri, Jun 10, 2011 at 12:56:30 PM | Arc Lines display as straight lines
Was the view you showed a small sacle view or something like 6"=1'?
You will find that Revit does not like very small units in small scale views.  And besides that... You can't see the problem in a printed view, just on the computer screen when you zoom in closer than the view is set to show at.
Sun, Jun 12, 2011 at 10:07:46 AM | Arc Lines display as straight lines
jawii
It's not the scale or the detail level. I've tried a bunch of different settings but the arcs still don't change.  (shown views are 1:5)
And as you can see on the attached .pdf, the straight lines does print instead of the actual arcs! -otherwise I wouldn't have posted the question.
Room Separation Lines won't display [ 1 2 ]
Mon, Feb 19, 2018 at 2:00:11 PM
15
Curved/Arc Grid Line - NOT DASHED
Thu, Oct 13, 2011 at 11:22:19 PM
multiple curved/ arc and straight joined path line issues
Wed, Feb 14, 2007 at 6:32:43 PM
Symbolic Lines in Family - Display in Project
Fri, Jan 24, 2014 at 12:44:22 PM
Curve Approximation Quality
Wed, Jul 20, 2005 at 6:04:05 PM
Page generation time: 0.3233
