19 Users Online (17 Members):
Forums >> Revit Structure >> Technical Support >> MITRE TUBE
12 Posts No Rating |
I have created a family for a structural brace made up of round tube. The tube has a connector on one end and welds to a canopy beam on the other. The conopy beam is sloped and I want to trim my tube to the same slope angle. I've tried to trim tube in the family to no avail. I've also tried to get it to trim in the project model and that won't work there either. Any ideas would be appreciated.
Thanks in advance.......Terry
P.S I'm using revit 2011
You should be able to add a void in the family to cut this element. Read my post from a similar thread on making a parametric void: http://www.revitcity.com/forums.php?action=viewthread&thread_id=17452
WW, I tried adding a void extrusion as suggested, once I thought about it I thought this should work but it's not working. It makes since to me to add the void and cut the geometry but I can't seem to make it work.
Thnks..........Terry
beam mitre |
Thu, Jun 18, 2009 at 9:38:18 AM
Gutter with no mitre joints |
Fri, Apr 24, 2009 at 5:06:20 PM
Cut a window into a tube |
Mon, Feb 13, 2006 at 4:29:00 AM
Need help: modeling tube to tube intersection w/ in-place families |
Wed, Nov 11, 2009 at 7:15:36 PM
Wiring a 3 tube light |
Thu, Jun 23, 2011 at 3:01:48 PM
