24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Roof showing on wrong level
11 Posts No Rating |
Hi everyone, I'm pretty new to Revit and this one is doing my head in. I've designed my roof and offset it from the baseline of Level 1 2400mm. It looks great and is in the right spot on the 3D views but because it sits above the cut plane it can't be seen in plan view. I need to be able to see the roof lines in plan view. How do I do this?
Create a roof plan view and set the cut plane as you need.
i'm quessing its overhead rooflines that you want, this is not possible automaticaly,
draw your overhead lines in the roofplan view and then copy them to the level below.
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
12 Posts No Rating |
to show the roof lines on a plan view,
in the plan view, go to properties , look for underlay, set to level above. your roof lines will show up.
oh awesome! Thanks geofm. That's done the trick
Showing wrong reference sheet on view title |
Wed, Oct 17, 2018 at 12:26:30 AM
14
Roof Help |
Tue, Jul 17, 2018 at 7:37:49 AM
Roof Plan Issues- lower roof showing above upper roof |
Thu, Dec 10, 2015 at 3:10:46 PM
Component hosts to the wrong level |
Tue, Feb 12, 2013 at 10:39:47 AM
Roof Plan not Showing in Site Plan |
Wed, Jul 12, 2017 at 12:03:32 PM
11
