Forums >> Revit Building >> Technical Support >> 3ds max site model imported to revit
Tue, Jun 7, 2011 at 4:00:17 PM | 3ds max site model imported to revit
swegin
Hello all-
We have done some conceptual work and renderings using 3dsmax design 2011.  We are now moving on and would like to place the modeled site from 3ds max into revit.  I have been fighting with this for 5 hours and cannot find a clean and simple way to do this.  Does anyone have any tips?
thanks,
swegin
Tue, Jun 7, 2011 at 4:08:08 PM | 3ds max site model imported to revit
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
ummm... export to dwg then import into Revit. thats not ideal but it would work. is it a complex topo or is it flat?
Tue, Jun 7, 2011 at 4:49:58 PM | 3ds max site model imported to revit
swegin
it is pretty complex. The site has various slopes as well as some terracing.  I have exported the model as a dwg and that is what i am currently working with, but it will not let me model by face.  I can only create topography with "create from import" command which is resulting in a VERY crazy topo
Wed, Jun 8, 2011 at 5:04:11 AM | 3ds max site model imported to revit
vector23
vector23 Avatar
2 Stars: 16 Votes
here we go again..
you are trying to mix DWG lines with revit elements..
the two mix like water mixes with oil.. they don't mix..
if you know how to use 3Ds Max- then just leave the
thing in there and use it as a reference and build it in revit..
if you don't know how to use Max- then import from there
as a DWG into a SEPARATE session of revit as a MASS element..
then use it as a reference there.. again- you cannot bring
DWG lines together with revit elements.. THAT you
have to do in your head and with your eyes..
Wed, Jun 8, 2011 at 9:57:31 AM | 3ds max site model imported to revit
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
Try downloading a 30day free trial of Civil 3D, export your Max file to dwg bring it into Civil 3d and export out as a CSV file, import CSV into Revit
  • Ability is what you're capable of doing.
  • Motivation determines what you do.
  • Attitude determines how well you do it.
Quote by:  Holtz, Lou
  • Life is all about the attitude
Wed, Jun 8, 2011 at 12:49:36 PM | cadman6735
vector23
vector23 Avatar
2 Stars: 16 Votes
Quoting cadman6735 from 2011-06-08 09:57:31
 "import CSV into Revit"
what is CSV? and how does that import into revit?
Wed, Jun 8, 2011 at 2:39:51 PM | vector23
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
It is a Points File, it creates a toposurface based on a points file from a civil engineering software application.
A points file provides contour data using a regularized grid of elevation points.  The file must contain x,y,and z coordinate numbers  and be comma-delimited.
Wed, Jun 8, 2011 at 3:29:55 PM | 3ds max site model imported to revit
vector23
vector23 Avatar
2 Stars: 16 Votes
thanks for that information cadman- i have a CAD drafter that draws
site plans for my residential projects- so i probably wouldn't be
learning about comma separated values too soon.. but i will
ask them what they know about it..
Wed, Jun 8, 2011 at 6:22:22 PM | 3ds max site model imported to revit
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
It's like a point cloud.  Lots of different 3D programs understand points.   It will look something like this:
property float x
property float y
property float z
end_header
-1.512405 -0.4910043 -0.6032804
-1.250832 -0.4626869 -0.5064426
-1.532215 -0.7658843 -0.8032395
-1.197465 -0.2622684 -0.8587961
-1.035731 -0.6643526 -0.8997931
-0.8060413 -0.199708 -0.8456047
-1.170134 -1.091409 -0.8985399
-0.7819144 -0.07030175 -0.8894563
-0.8000945 -0.8389311 -1.023358
-1.935415 1.397937 -1.237751
Although these are measurements with no scale, and not the same format as mentioned... this is .ply with the RGB values removed... Points in X,Y,Z are the simplest way to express a 3D surface, with coordinates for the vertices.
Edited on: Wed, Jun 8, 2011 at 6:23:17 PM
exporing revit 09 to 3ds max with lights???
Tue, Jun 2, 2009 at 5:53:27 AM
problems with Revit 2013 in 3ds Max!
Fri, Dec 14, 2012 at 4:25:44 PM
13
Got a problem with texture orienting from a imported revit model in 3DS MAX 2008
Tue, Mar 31, 2009 at 10:15:40 AM
RPC's won't render in 3DS Max after importing from Revit
Sat, Dec 17, 2005 at 9:10:50 AM
Exporting Revit 9.1 Model to 3ds Max, Material Issues
Tue, Oct 16, 2007 at 10:38:26 AM
Page generation time: 1.6693
