19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Lighting fixture properties
9 Posts No Rating |
Hey gang!
Revit includes a few light fixtures. Some of them need to be hosted by a ceiling and some don't. How can this property be assigned or turned off if I am creating a new custom fixture?
Thanks for the help.
Sean
Use the appropriate template. As a general rule, always create families non-hosted... And if you need them hosted later, nest the family into a hosted template and link any parameters.
9 Posts No Rating |
Assuming my family is already hosted, can I get rid of the hosting by changing a parameter or something? Should I start from scratch to rebuild it in the correct template?
Thanks.
Sean
You'll need to copy all geometry and paste into a new non-hosted family template in order to change from hosted to non-hosted.
Its much easier to go from non-hosted to hosted, which is why i suggest always doing elements non-hosted.
lighting fixture basic? |
Sun, Oct 16, 2011 at 8:00:31 AM
Tagging Lighting Fixture Symbols in RCP |
Fri, Dec 18, 2009 at 1:03:01 PM
Lighting Fixture |
Tue, Jan 8, 2008 at 7:33:08 AM
Removing constraints on lighting fixture families |
Tue, Apr 7, 2009 at 3:57:35 PM
gym lighting fixture |
Tue, Jul 22, 2008 at 2:20:59 PM
