Forums >> Revit Building >> Technical Support >> How to change the thickness of a mullion
Tue, Jun 7, 2011 at 8:58:10 AM | How to change the thickness of a mullion
shenlunglinnk
3 Stars: 2 Votes
Hi
How can I change the thickness of a mullion?
Please see the attached jpg.
The thick ness of my mullion is 201,5 as shown in the type properties, however it's gray out.....
How can I change?
Thank you very much.
Tue, Jun 7, 2011 at 9:21:08 AM | How to change the thickness of a mullion
This is a type variable.  You have to edit the type or create a new one.
Wed, Jun 8, 2011 at 2:24:32 AM | How to change the thickness of a mullion
shenlunglinnk
3 Stars: 2 Votes
Hi
Thank you very much for your reply.
I try to find the original family, but the thickness number 201,5 is not there .....:-(
How can I edit the type?
Best regards
Wed, Jun 8, 2011 at 7:57:12 AM | How to change the thickness of a mullion
You do not do this from the family editor (although you can).   Find the family and expand the types as shown attached.  Right click on the type you want to change and pick type properties to see the settings as shown in the second image attached.
Rules for the type seetings for mullions can be found in your HELP: Rectangular Mullion Type Properties
Fri, Jun 17, 2011 at 6:01:41 AM | How to change the thickness of a mullion
shenlunglinnk
3 Stars: 2 Votes
Thank you very much, I finally made it :-)
Curtain Mullion eats into vert mullion
Thu, Jan 22, 2015 at 4:49:08 PM
connecting horizontal mullions around a corner mullion
Thu, Nov 17, 2011 at 12:38:25 PM
mullion ang transom not fitting well [ 1 2 ]
Wed, Oct 9, 2013 at 11:42:10 PM
23
Change in rafter thickness in roof
Wed, Jan 6, 2010 at 7:28:23 AM
Wall line thickness
Mon, Sep 26, 2005 at 5:47:35 PM
Page generation time: 0.8989
